MTVR MK23 Transfer Case Info
Ward0481
9
93061, CA
I'm trying to source the transfer case output shaft seal going to the front end. Does anyone know what the transfer case is (make/model) and or where to source the seal?
Also looking for drivers side fender, the one that attaches to cab?
DeMilitarized
919
Gainesville, GA
It is an oshkosh 30000 transfer case. Seals are probably going to be expensive. This might be it not sure dont quote me on it. The brother to the 30000 is the 55000 used in the hemtt and m1070 HET. The fender is going to likely be impossible to find unless you find someone with a parts truck or pay oshkosh $2000 per fender. https://www.oshkoshequipment.com/products/detail/19/5457/Transfer-Case-Rear-Output-Shaft-Flange-Seal
NDT
5,890
Camp Wood/LC, TX
The seal should have a number on it, a bearing house can usually source any seal. If it turns out to be some kind of proprietary part, they can come up with a seal if you provide the retainer ID and shaft OD and width of the seal.
Ward0481
9
93061, CA
I think i have been able to source parts for the transfer case.. Ill follow up and share the info if it works out.
