MV Addiction filled. Reis the Beast M1078A0 is born
M1078MAN
893
SW Va, Roanoke County
Jumping for f'n, joy..
I tracked down the transmission double ** and no display problem.
Simply, electrical control cable input at base of tepss was loose. Once i unhooked it and reinserted, all my problems went away. Drove it to the original drop off location and back, about 2 miles
I am so freaken happy,
coachgeo-thank you very much for the prod-:beer:
Wheelspinner-have you made any progress
While i was on a roll, decided to take a look at the non functioning ctis module. Looks like we had a little fire.
I pulled all the goo out off it to see
M1078MAN
893
Mail Call...scored these 24v relays NOS on ebay
nsn 5945014211785
yes, looked like you tossed a grenade in it. anyone got a lmtv or hemit ctis module laying around they want to get rid of cheap
Man. double delivery- got a temp gauge..for future upgrade..amazon search DIGITEN 12V Red Digital Fahrenheit degree Thermometer High Low Alarm -76-257F Temperature
M1078MAN
893
Another day, another delivery.
All fleaba-
2/0 terminal-you can get dif sizes. search: Lawrence Marine Tinned Copper UL Stamped Lugs 8, 6, 4, 2, 1, 1/0, 2/0, 4/0 AWG
FIGURE 71. BATTERIES, BOX, GUARD AND CABLES (SHEET 3 OF 3)
door rod clips, hope 1 works search: 75450 Dorman Door Lock Rod Clips
Anco 91-20 blades search: New ANCO 91-20 Windshield Wiper Blade ANCO9120B
17 PAOZZ 0FW39 12417656-001 BLADE,WINDSHIELD WI................. 3
Jericho
69
Landaff NH
Ill save your pages for the occasion I ever get an LMTV until then you have done a great job, need a stickie page started, Please feel free to add to the M 35A2 M561 and M 931A2 parts pages with equal zeal ! great job
coachgeo
3,378
North of Cincy OH
there is a sticky on this forum about parts and where to get them. Been there couple years now and is kept well updated. (thanks wes simpson for starting the sticky)
M1078MAN
893
Ben kinda busy, but back at it.
Ordered some clearance lights. too small. looking for the round led's by truck-lite
Truck-Lite 07174 Military LED Yellow Marker Lamp w/ Tan Bracket
ordered some m4x.7x16 stainless Allen bolts and blind riv-nuts.
Still have not recd my Royco hyd fluid
also ordered the 150psi transducer for ctis
Ordered 2 OSHKOSH HUB CAP WHEEL 1833540
Cleared the trans error codes-next test drive
M1078MAN
893
Today was a great day..a SS Brother in Arms came to my rescue and sent me a CTIS Module, no name, a PO box in Ashville NC.
Who ever you are, thank you brother!.....I wont post any additional info about you.
After checking out the part numbers, and they matched, I took it out to the truck, and plugged her in. I now have flashing single light and all mods select-able. Now i just need to do some additional trouble shooting to why i have no working inflate or deflate.
Also, a great day, mail call
Recd these HET CTIS covers thanks to fleaBa. A little nip and tuck and they just might work, bolt holes look like they will line up, but they wont.
got to do some slicing and dicing, but great platform to start with
M1078MAN
893
Always welcome /Mail Call\
Thanks to the Amaz-on, picked up the 150 lb CTIS transducer
Search [h=1]AUTEX Pressure Transducer/Sender/Sensor 150/200 Psi Stainless Steel Compatible With Oil, Fuel, Air, Water (150 Psi)[/h]
M1078MAN
893
/Mail Call\- today, thanks to Amaz-on, recd 199 M4x.7 blind rivnuts.
28 PAOZZ 84256 ALS3-470-2.0 NUT,PLAIN,KNURLED M4X.70 (GRIP 16
Search CAK2-470-3.3, RIVETNUT, M4x0.07 (2.01-3.30mm GR) RND Body Splined, Low PRO HD, Steel, Zinc YLW (100 PK)
/Spent the day pressure washing, cleaning windows and waxing the carc [shinning the tires], going to enter truck of the day comp\
M1078MAN
893
Today was spent trouble shooting CTIS, and after a few hrs, think i have stumbled on the problem. I found that the right rear CTIS LINE TO TOP OF HUB WAS BROKE CLEAN OFF at the connection, hose only..Will get a line and see if that solves my problem.
Question, as a test, can i by pass the pressure switch just by jumping the two wire connector
Camel Driver
Gilberts Illinois
"think i have stumbled on the problem."
Myself, I will take lucky over good any day if it saves me time and frustration. Here's to many more "lucky" problem fixes!
BTW, you are making me very jealous. I was hoping to be working on our M1083 at the pace you are going. Unfortunately, I decided to go back to work at a "real job" for a while just to stash away some extra funds for the truck. But I will definitely be watching your progress with interest. Both for the good info and to do a little vicarious living. :jumpin:
Keep up the great work, Bill
M1078MAN
893
/MAIL CALL\ Today i had a nice surprise, the following was delivered ahead of schedule..I need a few more, just couldn't spend the 400 bucks
ctis cover.jpg.
GROUP 3307: SPECIAL PURPOSE KITS
FIG.291 RIM COVER KIT
1 PDOZZ 0FW39 57K1996 KIT,RIM COVER....................... 1
2 PAOZZ 0FW39 12422479 .COVER,RIM.......................... 1
3 PAOZZ 0FW39 12422589 .WASHER............................. 4
4 PAOZZ 0FW39 12422480 .STUD,RIM COVER..................... 4
5 PAOZZ 27783 3680G .VALVE EXTENSION,TIR................ 1
END OF FIGURE
291-
I guess I spoke too early, anther delivery, both via fleaba
9150-00-223-4134
9150-00-082-7524
9150-00-265-9408
Hydraulic Fluid, Petroleum Base
(MIL-H-5606) (81349)
1 qt can
1 gal can
10 gal drum
55 gal drum
qt
gal
