- 2,388
- 113
- Columbus, Georgia
So... Is "Soldier B" gonna drive the GPW in the parade next year?? HUH??
TWM uses a rare and little known straightening technique known only by a few elders as "Celestial Alignment".How did you straighten the frame?
My limited experience with Jeep frames has been that almost all of them are off in some way-either a high or low corner or out of square. All my experience with such issues involved frame benches.
My frame problems were with the front horns and the rear sections. I clamped sections of heavy duty 2" square tube to the problem areas of the frame while it was on the axles and wheels and then used a 6 foot landscape breaker bar to coach those sections back into alignment. Once they were at the TM specifications, I removed the frame from the axles and welded up a few cracks and I was good to go. But, it is quite possible the stars had something to do with it.How did you straighten the frame?
