redass73
- 1
- 0
- Greenfield, Indiana
impressive!...is the same 20k front winch like the 5 tons.
Where? Love to see it in person someday....TacticalTruck said:Jumbo lives in the Shenandoah Valley.
Jeff
LOL. To give you a little idea of the size of jumbo, go out to the back of your wrecker and have a looksee at the winch. THAT'S the winch on the front of Jumbo. Yep folks, it's a 45,000 pounder.redass73 said:impressive!...is the same 20k front winch like the 5 tons.
As other points made. But drives very easy, cut angle not so tight so ditch to ditch making the corner of a rural gravel road. I've not pulled an M747 trailer (now there is an appropriate Mil desgnation).Cdub said:how does the M911 compare to todays over the road tractors that pull 53' trailers.........is there much difference......???
Thanks,
C'dub
The GVWR is just OUTSTANDING..........I would like to see a semi parked nextNEIOWA said:As other points made. But drives very easy, cut angle not so tight so ditch to ditch making the corner of a rural gravel road. I've not pulled an M747 trailer (now there is an appropriate Mil desgnation).Cdub said:how does the M911 compare to todays over the road tractors that pull 53' trailers.........is there much difference......???
Thanks,
C'dub
Combined GVWR is 192,000lb (Tractor only - 85000lb on 4 axles). BUT remember the new HET is more as the M911/M747 was to small for the uparmored M1s.
M911No.2Diesel said:They didn't even bother to tape off the tires when they sprayed the wheels. And shouldn't the wheels be painted black?
Question: What's the M123s wheelbase? Also: Whats an M911s Wheelbase?
An M819s is 216.5" with an overall length (not including the boom) of 334"
