Need a part number for m923 exhaust gasket
acesneights1
21
20
CT
The gasket under my cab blew out. Flex to header on an A0.
anyone know a part number I can use locally ?
I can't seem to cross nsn 5330-01-1047354
aziator
-1
Sierra Vista, AZ
Does the V-Band from the turbo to the exhaust have a flat gasket in there? I pulled mine apart as I am building a 5" exhaust system and there was a gasket in there. Just something I am not used to seeing.
Guyfang
22,649
Burgkunstadt, Germany
Original cost to the gov, 0.73 cents. There is also a german company that makes, or made this gasket.
Bosch Rexoth GMBH Lohmann
Mannesmann Str. 29
Postfach 1860
58455 Witten
Germany
Tel. 02302-877404
acme66
Plains, Montana
I have been running mine with aluminum foil for a while now. Cut a 2 inch wide strip and wrapped it around the joint a few times and then put the v-band clamp carefully over the top of that. Truck passed it's annual inspection like that. Someday I will do it properly so I hope you find a source you like.
Ken
