Need assistant
CHIEFSONN
Tomorrow I am scheduled to pick up a trailer, after while getting fuel up yesterday we had a light rain and when leaving I found out that I had no directional.
So today while going over some of the tm's I found that I had one bulb inoperative, replaced it but still no directional. I then discovered that I have running lights at the rear but none in the front can I get some advice as to what I need to check for. (Nothing at the front and no directionals with
running lights at the rear, )
All my wires at the rear are not marked.
Jbulach
2,067
Sunman Indiana
Likely a combination of problems fist being a bad hood ground, or the housings themselves have lost ground. Jump a ground directly to the socket inside the housing and see if that gets anything lit. Directionals maybe the contacts inside the steering column lever need cleaning, just had to do this to mine, very simple to take apart and clean.
CHIEFSONN
Turned out to be a bad flasher. Directional and light switch checked out good, just wish l had tested out the flasher first.
Thanks for your reply.
