nyoffroad
- 661
- 93
- Rochester NY
I fell into a deal that I really couldn't say no to. I picked up a complete 6.5 turbocharger including both intake and exhaust manifolds, crossover pipe, 3" down pipe, oil lines, and a spare turbocharger and some other turbo parts I'm forgetting. Included in the deal is all the parts to put on a serpentine belt, water and power steering pumps crank pully, new alternator, and a bunch of other brackets including A/C. The guy also tossed in a new gasket set and set of head studs. All for $500, I think I got a good deal. I hate searching for and piecing things together and this is everything I need in on package. Unfortunately I can't start on the project for awhile till I get some others knocked out.
The engine this will be going on is on a stand right now, I'm going to pull the intake and IP and send the IP and injectors out for a rebuild. Anything else I should do before getting to far into this? The engine is stock with less than 30,000 mi and even thou it ran great I already did head gaskets and checked the heads for cracks. This will be run with a low psi of boost, I'm old and past the "flat to the floor stage".
