- 2,960
- 29
- 48
- Tiro, Ohio
Was doing some heavy hauling with the M35 and trailer when the transmission started making noise. It started in 5th, and by the time I was done the only quiet gear was 4th. Lot of fun driving 30,000lbs with 4th high and 4th low.
So finally pulled truck in garage to tear it down. Everything looked nice with the cover off, and no pieces of metal in the bottom. Pulled the main shaft while in the truck, nothing there. So dropped the transmission, pulled the input shaft, and found the cage for the input bearing had disintegrated. Luckily none of the pieces made it back to the inside of the transmission. So looks like replace bearing and I should be back on the road. Might do the main seal while I am here.
