I am trying to remove the plug from the block (above the oil filter) to use as the oil supply source for my turbo but it is putting up quite the fight, even after soaking for a few days in penetrating oil. A 1/4” drive extension doesn’t fit snug enough to be able to put a lot of force on and I don’t want to strip it.
Anyone have a good technique for removing these? The only idea I had so far was to buy some 1/4” square stock to fit inside the plug as that would be more of a true fit vs the somewhat rounded cornered 1/4” drive extensions. But open to more/better ideas.
