Oil pressure gauge and sending unit issues
muthkw25
486
Sayre, PA
My old oil pressure gauge stopped working. Installed a new gauge and still nothing changed. I have 24v going through line 27 and 24v leaving the gauge to head to line 36 to the sending unit. Ran a new wire to the old sending unit and nothing changed. Installed a new sending unit now and the truck reads 50psi. When I Rev the engine the gauge bottoms out to 0 and then back to 50 psi. The gauge can't be wired up backwards and I have power coming to and from. Any thoughts on what's causing the issue? The gauge is grounded and still misbehaving. Any help would be greatly appreciated.
MG2936
59
Lapeer, Michigan
I had the same problem on mine, after new gages and sending unit I found the ground wire in the harness was broken. ran a new ground wire and I was back in business.
muthkw25
486
Sayre, PA
I ran a separate ground wire from the gauge to the firewall and it's not working. Gauge is getting 24v. And 24v is leaving the gauge and the wire going from gauge to sender is new. Not sure what else could be wrong but the sender because none of the other gauges are malfunctioning. Just an odd situation. I ordered a mechanical gauge from autometer and it will fix the issue.
muthkw25
486
Sayre, PA
How's the battle going?
After battling with it, I bought an autometer mechanical gauge and fixed it. Wired it up. Looks almost factory. Found out when cold the truck will idle cold at 55psi, under throttle not fully warm at about 80 and when work it runs at 60 under full throttle and idling when warm at 26 to 28 psi.
