- 2,135
- 613
- 113
- Davis County, UT
I make these myself.
$35 per set of 4 straps + shipping
Located in Kaysville, UT 84037
These straps are designed to replace the oft missing, damaged, or sun rotted straps on military pioneer tool racks found on many military vehicles such as M35A2 / M35A3 (deuce and a half), any of the M39, M44, M809 and M939 series trucks, and possibly Jeeps and others. Keep your tools securely mounted; you never know when you'll need them to dig out a stuck rig or dispose of a body. Not intended for life safety devices.
Features:
NOTE: I do not certify nor guarantee assembled breaking strength. Webbing specifications provided for informational use only. Not intended as seat belts or life safety devices.
These straps are designed to be installed on a Military Pioneer Tool Rack similar as shown below:
(click to enlarge)
Features:
- Updated: Now a set of four straps!
- 12.5″ (31.7 cm) long (qty. 3) , 19.5″ (49.5 cm) long (qty. 1)
- 1″ (25 mm) wide webbing.
- MIL-W-4088: Olive Drab (OD7), Camo Green 483, Coyote, Foliage, Red, Black
- Nylon
- Type XVII, ~0.05″ (~1.4mm) thick, 2500 lb (~1134 kg) breaking strength webbing, resin treated for abrasion resistance.
- Repurposed Vintage mil-spec Dark Green Cotton
- Please note, the Dark Green Cotton was unstitched from NOS webbing gear so it will show signs of previous stitching and it has a little stretch to it.
- 100% Cotton
- ~0.10″ (2.5 mm) thick
- Mildew resistant & water repellent treated.
- MIL-W-43638: Vintage Natural color Cotton
- 85% Cotton & 15% Fortisan
- Type I, ~0.07″ (approx. 1.8 mm) thick, 600 lb (~272 kg) minimum breaking strength webbing
- Low stretch
- Black coated, solid brass tip, genuine mil-spec, meets MS51926B-3.
- Mil-spec spring buckle clamp, genuine mil-spec, meets MS51929A-2.
- Heavy, visible outdoor polyester or nylon stitching, UV resistant, anti-wick.
(click to enlarge)
