pre heating kit issue
johan77
47
limburg belgium
hi guys, did anyone an overhaul of the part that according to me injects the diesel direcly in the intake? mine is dripping fuel at the bottom end, not on the fitting nor the 2 lines connected to it on the right side (looking from the picture) but really on the bottom. i ask myself if there is some sort of seal in it, it looks te be an internal circlips sitting on the bottom . thats where the fuel drips out. i am thinkin to take it apart and see whats in it...Any sugestions ?
peashooter
205
Hanover, minnesota
This is a common problem. I ended up getting a replacement flame heater injector nozzle when mine started leaking. It ended up being a newer design (had a hex body). After replacing it still didnt work (but didnt drip anymore either). I ended up just pulling the whole system off as it i didnt want to replace the pump for it next. I also run some WMO with my fuel and dont think you are supposed to use the flame heater when mixing fuels. I just keep a can of starter fluid in the toolbox now.
