Pressure gauge port or????
rolling18
75
Portland, OR
After searching, unable to find info, probably not using the "correct" part names/ terms anyway..
on the drivers side of the motor toward the rear, there are 2 smaller filter hOusing looking things (not the 2 oil filters)
I dont know if these are for oil or fuel?
Anyway, there is a small port in the top with a screw plug in it. Would this be a place to install a pressure gauge? if so, what would be the range?
thanks!!
cattlerepairman
3,149
NORTH (Canada)
Fuel filters. Try the -10 Technical Manual (TM). It is good to read the operator level TM at least.
rolling18
75
Portland, OR
ok cool thanks, what i am referring to is the screw port on center top "rail" that connects the two... can a pressure gauge be installed there?
rolling18
75
Portland, OR
thank you! mine still has all the paint and no tool marks on the screw!!! wonder if i could substitute a gauge there.. hmmm[thumbzup]
rolling18
75
Portland, OR
true, I have only changed the ones under the truck pass. side.. I do filter my WMO to 5 microns tho.. no loss of power so far? hmmm i do have replacements ready to go!
Jeepsinker
337
Dry Creek, Louisiana
It is a good idea to change them, especially seeing that you never have AND that you run WMO. All I run is diesel and I still change mine regularly. There is a good chance you will see an increase in power that you wouldn't even know you were missing once you change the filters.
Floridianson
2,471
Interlachen Fl.
thanks!!
Yes you can check pressures there. you should be seeing 4lbs. with just the intank running with motor running 30 at idle 60 at high idle. filters are primary napa 3511 secondary 3512 and final #33540
1,168
Have you ever(or do you regularly) check your brake fluid?
Wildchild467
56
Milford / Michigan
Don't forget to check the engine oil! My truck is fairly good, but I know my truck inside and out and could almost tell you where the fluid levels are in every part of the truck right now. Doghead isn't trying to beat up on you, just want to make sure everybody stays safe out there. Keep on truckin' on! :driver:
