- 1,610
- 678
- 113
- Central NY
Allie in NJ contacted me about a dismountable hitch for his M932.
I went down and made some measurements of height required and possible "structures" available on his tractor. Strict requirement that it be easily removable so as to retain originality for shows etc., with the minimum of modification to the stock rear end.
He had a pile of scrap/off cuts that I snagged getting a feel for the strength needed.
Initially, I had wanted to hang the dropper from the pintle hook, then triangle brace up to some bolts on the frame - but due to the tight geometry of the tractors rear end, had to come up with plan B.
First pic is of the proposed idea.
On checking my M816, found that the securing nut on the front side of the pintle had a large 3/8" washer which could be replaced by a dropper assembly which would stay on the truck but be hardly noticeable.....
