- 2,638
- 8,450
- 113
- Alexandria, La
Question:
I'm connecting all of the various vacuum/pressure lines and I am at a loss for this one.
It goes back under the cab to a T and braches off to the transfer case and the little tube on the back of the filler tube.
There is a piece of soft tubing close to it, which I know was put there by the previous owner, but I have no idea where it would connect. There are no fittings close.
I imagine it's a positive pressure line fed from the same place the distributor is fed from, which leads to my next question:
I have 2 fittings going to my distributor (pictured). The top one (green one) is the one I replaced already,
the bottom one (rusty silver)
is on the bottom and is connected to the back side of the metering valve.
The -20 TM doesn't go into a lot of detail about this system. Any help is appreciated.
