- 2,875
- 4,125
- 113
- Olympia/WA
So I have a keyed battery disconnect. Sometimes when I start the HMMWV (m1123) the generator shows like it's about to start charging, it goes slightly into the green between glow plug pulses, but then drops back to yellow and stays there. If I turn off the engine, tap on the regulator a little bit, then restart, it will charge normally. As long as I don't turn off the ground disconnect it will continue to work properly, but if I disconnect the ground I have to tap in the regulator before it will charge.
Before I start tearing things apart, is it even possible to service the regulator for the 200 amp generator, or is my only option replacing it?
Or is there possibly something else I might be overlooking?
