Radio tray source
TexF18
32
13
omaha, ne
I just bought a m1123 and I am trying the source the 2 radio trays for the center console. Does any have a decent source for these. Ive only been able find one on ebay. Other question is do the bolts just thread into a insert on do you need nut and bolt to mount.
Mogman
8,289
Papalote, TX
IIRC the 1123 is the same as a M998 as far as the tray, on my original non turbo doghouses I used a short offset lower mount, unlike the ones in the pictures, and the trays bolted to the top bolt holes, unless an additional try is added to the bottom and then the lower set of bolt holes, I have all these brackets and lower tray because you cannot use the lower tray with the turbo dog house.
juanprado
2,709
Metairie/La (N'awlins)
I have the lower tray that bolts under the one you have pictured. It also bolts to the side legs of the top tray. $35 plus ride. Send me a pm
Mogman
8,289
Papalote, TX
That is the diag port, kinda like teats on a bore hog.
Although it can be helpful at times as most of all the electrical connections/signals go to that port
papakb
1,186
San Jose, Ca
Generally referrd to as the STE/ICE port. This stands for SIMPLIFIED TEST EQUIPMENT / INTERNAL COMBUSTION ENGINE
I definitely concurr with Mogman about newbies needing to read the manuals. The TM 9 2320 280-10 in particular. By doing this you can save excessive wear and tear on your typing fingers because it'll asnwer 94.73% of the questions we see repeated weekly on the Steel Soldiers Forum.
T9000
360
California
The TMs answered 89.21473% of my questions, but yeah, papakb is pretty close :)
aghumvee
177
Blairstown,Missouri
I have the radio tables with the lower tray.
I'm south of Kansas City, MO or I can ship.
I also have the 2 angle pieces for the dash of a m1123 that radio table mounts to.
