signalcorps
- 219
- 43
- Longwood Fl
It turned out pretty good.
Bilstein 33-230436 for the rear shocks?A little engine work done this week. Painted and mounted 12/24V battery isolator setup and plumbed the oil cooler and filter, New Bilstein rear shock came in too. New 8 inch wheel coming in tomorrow so I can swap out the 10 inch.
.I bought a set of 4 front shocks and will get them installed after new bolts come it. I have just about finished the engine. Fuel lines and oil cooler/filter are done. Alternator and HPMX card completed. I sanded down the carb airbox and found a number on it. 657. I still have to install plug wires and set timing. Also the valve covers after I check the valve adjustment. Exhaust will be last and will be a big PITA.
