Ronmar
- 6,796
- 113
- Port angeles wa
That's how most generator controllers do it...
Dumb question…..OK... Prototype testing of the remote control is up.
Right now none of the outputs are hooked up. I figured I'd burn it in a bit before connecting everything, in case it decided to go all "Maximum Overdrive" on me.
Due to the lack of a real momentary option, and the fact that I don't see a need to run the winch from miles away, I'll be controlling the PTO and Winch enable switches, but not the in/out functions. For that I'll be using a wireless winch remote. I'm considering a couple of options for the actual winch controls.Dumb question…..
Are you planning on remit controlling your winch over cellular? That sounds very dangerous to me.
I can only think of a couple things I would want to control remotely on the dash of my truck. On/off, start, and a diesel heater. Maybe power locks and light bar…. That it for me.
If you like automating for the fun of the project, more power to you, but for practicality, simple is usually better.
Climbing in and out of the cab repeatedly at 51 years of age is not "simple". I'm a lifelong nerd, I'd spend considerable time and money to eliminate mundane, time consuming physical tasks like climbing in and out.This whole thing sounds like you need to take the tires off a Tesla and weld it to the top of your LMTV simple is better
I understand getting in and out of the cab 43 here and over 400 pounds not the most pleasant part, but its all part of it.Climbing in and out of the cab repeatedly at 51 years of age is not "simple". I'm a lifelong nerd, I'd spend considerable time and money to eliminate mundane, time consuming physical tasks like climbing in and out.
I'm not too worried about it not starting. The relay I'm using has a built in timer that will stop cranking after x seconds.You can use the cell phone to initiate the sequence. You just need a more robust controller between with safe fail modes.
In my example, using the counter with alarm output to stop the start signal has a risk. If the mag pickup fails the counter will never see engine speed and the crank cycle will not terminate. There are a few options here. The controller has two relay outputs. You could put them in series and program the first relay to break the start signal if there is no RPM after a delay. You could also use an external time delay relay to break the signal after a set time regardless of what happens.
