Replacing the CV Axles
Jtalbot
13
Charlotte, North Carolina
So I started to replace the front CV axles and watched a few videos before hand. Got the tank lifted and removed the passenger tire. Removed the cap, then the bolt, then made my way under the tank. Started to remove the bolts from the rotor but was unable to get them to budge... I also noticed the rotors turned with the vehicle in neutral, drive, and reverse (Emergency brake applied). Used another tool to keep them from rotating but was still unable to remove the bolts. Didn't have access to a lift to use any breaker bar for leverage. I tried using an air wrench but the CV shaft was too close and didn't allow clearance. I got frustrated from fighting with it and it started to rain. I reinstalled everything and called it a day. Before I attempt to tackle the job again, where did I go wrong?
ken
24
Houston Texas
Losen the bolts before you lift the tire. If you need to. Jack up the tire and rotate it to reach the other bolts. Then lower it back to the ground to break them free. Then lift up the truck, remove the tire and finish up the job.
Ajax MD
1,420
Mayo, MD
LOL...I'd really like @Jtalbot to come back and say that he was able to break 'em loose.
I know I'm going to be doing this job myself and his story is kind of freaking me out!
Jtalbot
13
Thought about that later... rookie mistake
Try a really long box end wrench.
will do
You and me both!! haha
sf1954
Richmond, Va
When I installed my half shafts, I put a 3/4" (I think) wooden dowel in the access plug hole. It would bind with the wheel spindle and lock up everything from moving. When I needed to rotate the rotors for better access I simply removed the dowel, rotated and reinserted it. It also helped in torqueing the bolts. Just be careful not allow the dowel to splinter or get broken. If my memory is good, I cut the end of dowel off after completing 2 half shafts.
Good Luck
Milcommoguy
2,123
Rosamond, CA
TIP or TRICK...? Try blocking of the rotor to remove - replace the 6 half shaft bolts with truck tires off the ground. Front or rear.
I slip a 5/8 open end wrench over a vent web in the rotor. With the angle of the open end... one way it will lock up in the rotor webs and can be held OR my choice let it rotate around to stop against cross member or brake caliper. Pre tighten the ones in view.
Pull the wrench and using the wrench pick another spot on the rotor and lever rotor around to next set of bolts.
Finally, rotate around again and torque to spec. 57 - 60 Ft Lbs plus Nord-Locks and the red stuff.
CAUTION> If backing off of preloaded wrench, it might fall out of web - vent and gravity will take over. One person job, easy, no blood or bruised body parts.
AND won't work if E brake is on...DUH.
Righty tighty. See the pictures, CAMO
Have solid rotors ? U-R SOoL.
Bulldogger
608
Quantico VA
View attachment 788501View attachment 788502
+1 for locking the rotors (carefully). I've used everything from a wrench to a Craftsman screwdriver. Just find something that will bind it and proceed carefully. Some penetrating spray won't hurt, but be sure to clean it off the rotors after and try not to get it on the pads.
You'll get 'em!
BDGR
