blutow
- 498
- 63
- Austin, TX
I'm putting new tires on my m1123 that I recently got from auction. I wanted original hmmwv rims and decided to swap to 24 bolt wheels as long as I was messing with it. I also decided to go with the original runflats, so I had to figure out how to deal with those. I know some folks do without runflats and some use the PVC inserts. I'm not comfortable running without a bead lock and trailworthy fab appears to be out of business, so I figured I'll try the stock runflats first and I can look at other options later if needed.
There is a good mix of youtube content on runflat removal and install. For removal, it seems it's either pulling them out with a rope tied to a truck and yanking or using an engine hoist to slowely extract the donut. I elected to use the engine hoist technique and it was quick and easy with no drama. I think the truck yank approach is better youtube content, but I wanted to save the runflats and it seemed a little out of control (but did look like more fun).
For installation, there were multiple examples of people using big ratchet straps and a couple folks using the original runflat compression tool that has a strap and crank. The tool was pretty cheap on ebay and I figured "it's the right tool for the job", so I bought one. In my opinion, it's a pretty crappy tool (and a little scary), but it works. I got 2 tires done so far, the 2nd was much quicker than the first after figuring out a technique.
For anyone else attempting this with the compression tool, a couple tips - I recommend using a big vise grip to hold the compression tool steady when cranking on it and also continuously grease the teeth as you are cranking. When installing, also use a couple ratchet straps connected to trees to pull the tire beads out at the bottom a bit, that made getting the runflat easier to slide in.
In the video linked below, you can see another approach using a hydraulic jack (I saw this after I already bought the compression tool). It certainly looks easier than the compression tool, but I'd be worried about that jack slipping one way or the other before pressure is released. The amount of energy stored up in these compressed runflats is scary stuff. I did use his technique of pulling the tire beads apart at the botton and that worked well.
https://www.youtube.com/shorts/Vw5RhUZ7v9Q
2 down and 3 to go. I really like the look of the stock 24 bolt rims and they were a cheap upgrade, just needed a little labor and paint to clean them up.
