SHC35 and SHC60 Battery
rolling18
75
Portland, OR
You people that got your heater running,
does yours make it continuous clicking sound like tick tick tick every few seconds?
Or a sounds like it's coming from the control box?
ZiggyO
428
Nebraska
Got the heater working this weekend. Ran for 15 minutes. Charging indicator never came on...Anyway to verify charging system is working?
It can take sometimes a half hour or more for the TEG to reach enough output to initiate charging. If you need to check the TEG, there are two terminals coming out near the combustion chamber end-- you can check there for voltage output. Bear in mind, it can fluctuate with temperature. If you are showing voltage there, then look at the switchover relay on the main board---- they like to stick.
ZiggyO
428
Nebraska
Also bear in mind that the charging system also looks at battery state before switching over to the TEG to charge-- if it sees high enough voltage on the battery, it will not activate until battery voltage comes down--- In my case, when I use two car batteries versus two smaller batteries with my adapter, it will take longer for the charging cycle to kick on with the larger batteries.
torp5061
South Dakota
Great information...Thanks!
torp5061
South Dakota
You know I already make a battery adapter for these-- it addresses the temp sensor and heating element issues----- I don't advertise as much as I should but several members here have bought them......
Anyway, battery size does not matter as long as they are matched relative to one another (i.e. don't use a group 31 with a lawnmower battery)---- the heater looks at charge rates and if it sees an imbalance, it will throw a code and shut down-- it may not do it right away but it will happen sooner or later.
Z
heater is shutting down after 10 minutes,
error code 18 ...any suggestions?
ZiggyO
428
Nebraska
Look at the thermal breaker under the rubber plug on the lower body of the heater. Even if it is still pushed in, fully check it for continuity.
Z
Third From Texas
6,332
Corpus Christi Texas
TM Troubleshooting (assuming OEM battery):
TROUBLESHOOTING PROCEDURE FAULT CODE 18 – BATTERY TEMPERATURE SENSOR
SYMPTOM Heater inoperative, the system fault light repeatedly flashes eighteen times, and repeatedly sounds eighteen audible warning tones. MALFUNCTION Loose battery connection.
CORRECTIVE ACTION Push the battery pack connector in securely and ensure locking tabs have engaged completely. Refer to WP 0005 00 if necessary. MALFUNCTION Damaged battery connector or wiring.
CORRECTIVE ACTION If the connector or wiring leading from the battery pack connector to the battery pack is damaged, replace the battery. Refer to WP 0043 00 if necessary.
MALFUNCTION Battery sensor malfunction.
CORRECTIVE ACTION Replace the battery with a known good battery, or a new battery. Refer to WP 0043 00 if necessary.
MALFUNCTION Damaged harness connectors or wiring.
CORRECTIVE ACTION If the connector or wiring on the inside of the heater from the battery connector to the main control board is damaged, replace the electronics box assembly, complete with wire harness IAW WP 0048 00.
