- 1,198
- 453
- 83
- Spartanburg,SC
See post #17 above.Where did you get the shocks, I have a buddy that needs a set.
You only got half...and they look bad.....you should have 2 long, 2 sort shocks, and 4 green tubes...2 of which will slide into the other 2....and if dented...they may not slide in.View attachment 838877
Got these from Eastern and they're a little rough. I don't know if they will work but I will give them a shot. These were $50 plus shipping
I'm interested in what you have if they function and look better than these.I have used sets available.....not junk like those other guys.
Hey Greg are those the heavy duty ones or the regular onesMine are good...all 4 , $ 100 plus shipping.
You will need 4 ea. clip retainers p.n. 12339617
I'll take them.Mine are good...all 4 , $ 100 plus shipping.
Zip code please.I'll take them.
90069Zip code please.
Yes! Send me a DM with your PayPal infoGamble...you getting these ?
Another guy wants them.
You don’t compress them, you remove the limiting ropes, attach each lift shock to either top or bottom ball, insert retainer clip, open the hatch to the point it’s standing straight up, insert other end into ball, install clip and your done.So.... Whats the trick to getting the shock to stay depressed long enough to get it bolted in.
Sure would help to have another set of hands. But I'm solo, so I guess I will have to use a rope to tie the roof in a vertical position if I can get it that high in a RELATIVELY safe mannerYou don’t compress them, you remove the limiting ropes, attach each lift shock to either top or bottom ball, insert retainer clip, open the hatch to the point it’s standing straight up, insert other end into ball, install clip and your done.
helps to have a helper….
Back up against a tree and open it "rumble seat" style.Sure would help to have another set of hands. But I'm solo, so I guess I will have to use a rope to tie the roof in a vertical position if I can get it that high in a RELATIVELY safe manner
.View attachment 849427
Welp, got one in and it was a serious struggle. Then this happened on the second.
