Small -spin on- fuel filter change interval
Defcon-1
45
South New Jersey
Hi all, very basic question. If I change, drain, and maintain the large first filter, how often do I need to change the little one? Seams like it could last for decades.
Good question, lots of variables to truly have a definitive answer, I guess it would vary on engine hours / mileage + rpm average, quality of fuel, if using fuel additives, etc. If you have the 8.3 (not sure if you have the NHC 250) I've read that the little filter can be 2 years / 22.5k miles, but some guys do it annual or at 1200 engine hours. I think the little filter is cheap enough to do it more often, but that's just me lol. Do you have the canister-syle filter for the main fuel filter or did you do a spin-on conversion? That's next on my to-do list actually, will be much easier of a filter-change with a spin-on, that way the little filter will see even less water / dirt if I do that one more frequently haha.
ericp351
erie Pa
I have the little 8.3. After servicing the large filter, I thought the little guy is getting a "free ride".
Defcon-1
45
South New Jersey
It probably is if the main fuel-filter is doing its job / is being serviced routinely and drained frequently. I wonder what the engineering perspective was for the little fuel filter 🤔
ericp351
erie Pa
My GUESS is that the little one was general spec by engine maker. Military may have said - "not good enough", and kept proven bigger.
98G
Former SSG
4,025
The 8.3 started out with the little filter only, and they were clogging too easily so they retrofit the large canister filter in front of it.
Not all of the A2 trucks have both. Some have the little filter only.
