coachgeo
- 3,383
- 113
- North of Cincy OH
you create a way for water to get in. Beside it is not a solid plug of rubber. There is an inner wedges or something to that effect which force the plug to expand as you turn the T handle.Couldnt you just take the plug and drill a hole thru it while its in the tube so you could put a long shank good padlock thru the hole just be sure to stick a rag /plug of some kind to be sure to get all the shavings out of the neck or just remove the neck and drill it on a bench and wash out with brake cleen .
