Tension Spring Safety Question
swbradley1
Modertator
1,558
Dayton, OH
I have a newer trailer with a gate/ramp. To help raise and lower the gate/ramp they put a spring on one side. Works well and I check it often but it was pointed out that it could break and cause injury. I agree but I need a way to make safer.
I could put a chain through it or a cable to try and catch but I don't know if that is the best or safest way.
Any ideas?
thx
19,124
Any ideas?
thx
I agree that if the spring breaks, the gate/ramp might fall on you.
I wonder if there is a maintenance schedule for those springs?
I have a larger trailer that is hydraulically power up and power down.
I t doesn't have a check valve in the system - so if a hose breaks - You better run because the fluid will spray you and those ramps are about six feet tall and about two feet wide. All steel... If they fall, it is gonna make a bad day into a really bad day.
You could definitely have a catch cable.
Regularly inspecting the springs might be the best plan of all...
swbradley1
Modertator
1,558
Dayton, OH
Hydraulics breaking I understand, my backhoe broke a swing hose and blew out fluid all over the fence line is was pulling. Luckily it below and facing away from me.
A cable sounds like a better solution than a chain.
chucky
18,748
TN .
Youve got the idea just run say some 1/4 in cable while its ramp down and stretched out thru the length of the spring coming out both ends then make an eyelet on each end and self tapping screw into what evers close to capture the travel if the spring breaks ! They make ramp assist that bolt down where the spring is enclosed in a square tube and just a cable comes out the end of it to the ramp https://www.googleadservices.com/pa...L31us6EAxVZ48kDHQRGDGgQ9aACKAB6BAgEEBc&adurl=
swbradley1
Modertator
1,558
Dayton, OH
That's easier than my idea of laying a dead raccoon across the spring to dampen the event......
