tie rod ends cross out?
snowtrac nome
137
western alaska
if you take one to napa they should be able to take some measurements to get you the right one. At one time I had the part numbers but have since lost them napa did have them available in warehouses in the lower 48.
snowtrac nome
137
western alaska
the older trucks had a drag link with an end on it and an adjustable rod end on the other end. When mine failed I replaced it with a nos unit found on e-bay. I would love to find a commercial replacement for both that use a greasable end rather than the non serviceable that merritor supplied s&s
tow2gunner
Elkton/MD
tie rod ends
I have a 1997 M1078 - ordered from these below.
1) (2) (3) (4) (5) (6)
ITEM SMR PART DESCRIPTION AND
NO CODE FSCM NUMBER USABLE ON CODE (UOC) QTY
GROUP 1401: MECHANICAL STEERING GEAR
ASSEMBLY
FIG.160 TIE ROD AND TIE ROD ENDS
1 PAOZZ 78500 A1-3102-U-2881 TIE ROD,STEERING.................... 1
2 PAOZZ 78500 K-2412-Z .PIN,COTTER............................... 2
3 PAOZZ 89619 10QH39P1 .TIE ROD END,STEERIN RIGHT HAND........... 1
Mack 10-QH-39-P1 Drag Link End $40.00 https://www.mixerandplantparts.com/Mack-10-QH-39-P1-Drag-Link-End-p/10qh39p1.htm
PAIEM99900 PAI MACK 10QH39P1 ROD,END,KIT $26.33 https://store.reliableindustries.co...ler-parts/mack/pai-mack-10qh39p1-rod-end-kit/
4 PAOZZ 89619 10QH 310P1 .TIE ROD END,STEERIN LEFT HAND.......... 1
Mack 10-QH-310-P1 Drag Link End $40.71 https://www.mixerandplantparts.com/Mack-10-QH-310-P1-Drag-Link-End-p/10QH310P1.html
PAIEM99500 PAI MACK 10QH310P1 ROD,END $26.33 https://store.reliableindustries.co...railer-parts/mack/pai-mack-10qh310p1-rod-end/
Dock Rocker
71
Jackson ms
ASSEMBLY
Let us know how they work.
coachgeo
3,378
North of Cincy OH
I have not had any issues with them. Have only driven about 200 miles so far.
Sent from my Pixel 2 XL using Tapatalk
update on this is working out for you? Is your drag link of the type with the removable ends on both ends?
what came first in production..... the solid one with one end fixed??? or the shaft with both ends replaceable?
on the shaft with removable ends.... is it a hollow tube??
If hollow anyone ever see in it to discern wall thickness aka.. tube ID/OD .... got pictures ??
Reworked LMTV
1,158
TN
I'm a bit confused. Are these the drag link part numbers for the NEWER part with dual replaceable ends? I'm guessing not. I have a NAPA, but it is a tiny store. Doubt they could cross anything much. I only have access to the older TM's about the drag link. Anyone have access to the newer one's with the newer link?
ASSEMBLY
