spankybear
- 830
- 93
- WA
I hope this isn't a question as radioactive as chili with or without beans but here I go. Mixing load rages. I know there are load range D and E tires out there. I only need to replace 2 of my tires (well actually just one but... want to keep the same type of tires on axle ) I understand I will never have the load the military carries and don't meed the higher range. What harm would it be if I had 2 Ds and 2 Es on the truck. Of course I would keep them inflated the same and under the D max PSI. I would also keep the same range on each axle. I am thinking somewhere somewhere around 30PSI.
I do know and have read the warning on the side of the tires. I understand if I had an armored truck and running max weight I would not want to to mix lower rated tires.
And a question less hazards that 9 vs 45... Do load range D tires ride better, or softer, or less knock the kidney stones loose. I want to get tires order this week and trying to decide what way to go.
