- 791
- 795
- 93
- W.WA
Riddle me this: My M1097R1 has a GVWR of 10,000 (per SF97), truck weight 5,600 lbs, carrying capacity 4,400 lbs. I don't have the slant back on my truck and it just looks like a 4 door pickup.
According to Wikipedia, this would make it a 3/4 ton.
According to this random equipment site I found in California, this would be classified as a Class 2, Light Duty truck. (Class 3 starts at 10,001 lbs) The ton rating on this site also would consider it a 3/4 ton.
Would you all consider this accurate? Is there any official designation by the gov't? I know HMMWV's vary (for instance my M1114 has a GVWR of 15,500 lbs).
I'm filling out registration paperwork for the M1097R1, for the purpose of this discussion. Would a DMV want the conventional ton rating of 3/4 ton even though this is a range which is far above 1500 lbs or do this want the actual capacity? The paperwork contains check boxes for 1/4, 1/2, 3/4 and 1 ton and a place to write in anything above 1 ton. This seems to follow conventional ton ratings.
This is for Montana, if it makes a difference.
