Traded my A3 for a Bobbed A2
RIDDLE1
Americus GA
Well I traded my M35A3 for a bobbed A2, W/W, & C Turbo last week. It was bobbed by a SS member. I am sure you have seen the truck before but I'm pretty proud of it.
There are a few things that I am gong to have to fix on it. It has an oil leak on the front of the motor that I can't tell where it is coming from and a fuel leak on the injector pump. I have no idea what is causing either of them but I am going to get to the bottom of it! I might need some help along the way!
I also have to install the PTO and winch drive shaft. I'm looking forward to getting to know this truck.
Well here is the pics and wish me luck figuring out what is causing the leaks!
bjsmith
zachary,la
Where are you getting your wheels? How wide? What backspacing? and, how much $ per wheel?
not sure if im going to buy some made or what i will probly do is buy the hemmt wheels from a place that driving distance new for $100 each then get my friend dad who has machine shop at his house to cut the stock deuce centers out and weld them flush with where the hemtt wheel bolts
