Plane Fast
- 3
- 18
- Panama city FL
Well finally got around to looking over my 802's I bough this summer. First thing
I did was pull the exhaust and intake manifold. Thankfully the gens had zero signs of water!![Clinto :clinto: :clinto:](https://www.steelsoldiers.com/images/smilies/snoopydance.gif)
(That is paint not rust)
I think this is due to the fact that they lived their lives on a
trailer. Which was usually tilted forward, so rain did not pool up on the top.
Number one gen has 600hrs and number two has 1300.
I changed out the fuel lines and filters. Drained the radiators and flushed out the fuel tanks best I could. The battery's are weak, but I think I can get them back. On priming the fuel pumps. I found it's best if they have set for a while without running. Crack the fuel line at the top of each pump. Use the electric pump to pressurize the system good. Then crank the motor a bit. Then let it sit for an hour or two. The fuel should help get the plunger unstuck. I had good luck with this once I remembered to do it on the second gen. I did have to replace the starter on the #2 gen. The solenoid was bad.
Found it was just as cheap to just get a whole new starter.
Once the battery's were charged up good. I gave it a go at starting them.
They fired right up!
Oil pressure was good and both had normal water temps. I only had time to check the voltage at the convenience receptacle .
No load test yet. I want to go through and check for any wire chafing. Found a few spots that will need rubber to protect the wire bundles.
I want to do the fuse mod as well.
They need paint and good cleaning. Not sure what I will do with them yet. Power here is very reliable. Even during the last Cat 1 hurricane. The power never went out.
![image.jpg image.jpg](https://www.steelsoldiers.com/data/attachments/412/412277-fcb2be05452195368bc6908c21c8638e.jpg)
![image.jpg image.jpg](https://www.steelsoldiers.com/data/attachments/412/412278-801bae132359267f887e7ed37039e13b.jpg)
![image.jpg image.jpg](https://www.steelsoldiers.com/data/attachments/412/412283-c1f056a9a8156883dff7f72a4883ba7b.jpg)
![image.jpg image.jpg](https://www.steelsoldiers.com/data/attachments/411/411341-26777d83a398e5565221e0cc3b9a4607.jpg)
![image.jpg image.jpg](https://www.steelsoldiers.com/data/attachments/412/412284-6f00b1377b18219c11b80ade399f006d.jpg)
![A toast to MV's :beer: :beer:](https://www.steelsoldiers.com/images/smilies/beerchug.gif)
