U-Joint question
mutt_r
31
Lower Saxony, Germany
Hello Everybody,
From the manual TM -34P I can see two different u-joints for the Deuce used on the prop-shaft forward rear axel to rear rear axle and trans to front axle. I do not mean the bolted prop-shafts.
The lubrication fitting is either straight or in an angle. In my Deuce i've the one with the angle which are listed with P/N CP160X. The others are having the P/N 5704135. Will both fit? Are the ones with the angle easier to handle with the grease pump?
Thanks in advance,
Richard
