upstate ny /pa area 8.3 pump help ?
sweetk30
horseheads,ny 14845
anyone in the upstate ny / pa boarder area . near horseheads . zip code 14845 .
might need to change out the I/p on the 8.3 and not sure how to set final timing spec .
I have read up on bar over the motor for tdc#1 and plastic pin in cover goes in .
but from there it gets real dead on info . how do I know the pump body to timing cover is set in the correct place ? as the 4 mounting holes are slotted .
and might wana turn up the pump just a bit if we can .
any help would be great . trying to diagnose a under power motor .
old motor did good and drove truck nice till it blew a rod on #2 .
new/used replacement motor is non m-series motor but 8.3 . got few details to finish yet on full swap over that the last shop skipped . . . .
74M35A2
313
Livonia, MI
To set injection timing, you need the dial indicator kit and extension to do so. Set cyl #1 to TDC on compression, push the pin in on the back of the timing gear cover, remove the delivery valve for #1 on the IP, install the dial indicator, and compare plunger height vs timing chart. Adjust as desired. Most RV guys set their injection timing to around 16 degrees for max efficiency on the 8.3. Timing kit is about $160-$200 on eBAy. Adjust via slots, or by re-indexing pump gear to pump shaft if need be.
sweetk30
horseheads,ny 14845
not to be rude but did you even read my post .
I said I read the set the gear to tdc with the plastic plug and bolt in the pump .
my question was how to set the pump body to cover timming that's adjustable.
almost every link you click in your search or the same way I search it is talking plastic plug to set timming .
74M35A2
313
Livonia, MI
You'll need to do it by using the dial indicator method. Get the tools from eBay, and the timing table from any Cummins dealer via the engine serial number. For example, the injection timing is stated as 8 degrees on my 6CTA8.3 engine ID tag. There is no magic mark of where to just bolt it down and run. I could submit a picture of where my pump is clocked per the factory setting if you want to try that, but that won't guarantee it will be close or correct, but it may get it at least running though. The push pin on the back of the timing cover only indicates engine #1 TDC.
