maniatopoulosg
- 7
- 18
- Miami
Everyone I would like to thank you all for the endless knowledge I have gained here
I am new to the mep scene
I purchased a unit 803a
Had it sitting outside for a month
I starters it up the voltage gauge was a bit erratic I tried to open the throttle and it shot that hz way too high was nervous that there was something wrong with the voltage regulator shut it off got my tester went back started generator checked faces all were giving normal voltage shut the machine off switch the three-phase check that too everything was normal I followed one of the treads about voltage regulators and I adjusted regulator seems like everything is working my question is when a voltage regulator fails does it feel completely what does it start showing signs
Thank you all for your help
