Want to put A/C in a M925A1... anyone got pictures of their install?
ScubaCat
Olean NY
Mine on low at 95 outside will give you chills. It doesn't have to work hard at all.
Sent from my SM-G935P using Tapatalk
I told people that these would be able to turn your cab into a meat locker...These were meant to cool/heat a MUCH larger MRAP interior. Did you choose to mount so high because you wanted to keep the bench seat? Another guy mounted his on the floor between two buckets.
simp5782
Feo, Fuerte y Formal
9,285
Mason, TN
Yes i kept the battery box but modified it with an LMTV seat. I put it high to blow towards me and to blow the air towards the floor to keep the heat from rising
Buffalobwana
170
Frisco Texas
Wes, what compressor did you put in it? And is that an LMTV evap unit? What condensor did you use? I'm considering a condensor mounting spot like yours this time. My old spot/system works great, but won't on a M931A2
I know my red dot system and how it works, but in yours what activates the fans? Pressure switch in the receiver/dryer or some sensor in the evaporator?
Im asking, because I am about to do another install, but some components and mounting locations differ from the previous install and you just mentioned LMTV as some of your source parts. Now I'm curious as I believe I have a LMTV compressor in a mostly red dot system.
I read 74M35A2's description of compressor and fan operation and am curious if your unit has a place for your compressor wire or if you engineered it to just run off the condensor fan switch.
simp5782
9,285
Mason, TN
Condensor is an MRAP unit made by MCC on ebay for 200 shipped. Compressor is just an eBay unit. The blower unit is both heat and AC and cools the rear of an Mrap unit. The 6 man area made by MCC as well.
24v hot to the condensor relay. Evap Probe controls thru the AC signal wire to the condensor pressure switch. The pressure switch is a dual high and low switch. It turns the fans off and on. I jumped the wire off a fan to the compressor. Pressure switch kills the fans for a reason then the compressor turns off. //cloud.tapatalk.com/s/59488cc4173e7/Screenshot_20170619-214405.png?
simp5782
9,285
Mason, TN
Moved the thermal probe in the evaporator from the center to an outside fin section. Ambient temp of 88 degrees and 70 percent humidity blew nearly 40 while driving. 20170627_204309.jpg
74M35A2
313
Livonia, MI
40F degree outlet is about the best possible. Consider it done and successful. That is a 40 degree temp drop compared to ambient. Nice job.
