Josh
12
Portland, Oregon
Cranked the fuel way up. Can now hover around 1200ish on a good hard pull. Doesnt stall out in second anymore when ya let the clutch out. Changed the belts, changed fuel filters. And put about 150 miles on her.
Clay James
Reno/NV
I flushed my cooling system and replaced all the hoses, belts and the cracked oil cooler cover. I also converted the primary fuel filter to spin on. No leaks :jumpin:
Gastrap
153
Central Iowa
Installed a brand new radiator, hoses & thermostat, H4 headlights, and a bar buoy drink holder8) Changed oil & filters & checked tire pressure & changed belts.
Took her to the shooting range today & then checked out my selectro lockout hub function for the first time.
DieselBob
13
Arnold Maryland
Started mine for the first time in a couple of weeks. Started as soon as I pushed the button. :-D Needed to take some pictures for the insurance renewal, this can't be good. :roll:
scoutmanadam
richland, washington
installed a generic ignition switch interrupting the power wire to the push button. installed a donaldson muffler to make it a little more neighbor friendly. and replaced the wiring to my heater blower motor switch.
4,647
This week? Not much at all.
I got my bottle jack out to use on my samurai from the deuce.
The five ton got moved to show it to a prospect buyer.
308
11
Bear Creek PA
I drove the M211 50 feet and blew a brake line. the one from the master cylinder to the brake light switch. Made a new line and fixed it, went another foot and blew the line from the switch to the air pak. Decided I was not driving it that day. Fate was giving me a message, stay parked !
Katahdin
23
Scarborough, ME
Took a fender off so I could patch a rust hole and repaint the entire fender. This will be my first attempt at welding a patch so I was practicing with a Mig welder on scrap metal last night.
big1096
Essex, MD
Finished my brake/wheel seals/tire job. Changed fuel filters. Filled the fuel tank for an ungodly amount of cash...
Note to self: start looking for a WMO supply and build a filtering setup.
ryker725
Luling, La.
I went to start it last week and nada.. Batts were dead.. Could not get them to hold a charge enough to start it so I called a buddy of mine with an auto repair shop and was trying to find something to fit in the battery box at a telatively cheap price. Interstate refurbs would have required that I modify the box and re-do some cables. I found a guy that sold the square military batteries (US 6TMF) so I bought a pair from him. Had to fill with acid and trickle charge before use but they work great..
Other than that I got the new blinkers in from Eric's so I put them on the truck and wired them up. After that I drove it around my property......
Munk
Nelson, mn.
recovered 2 chevy pickups, 1 ford pickup and a explorer. the explorer fell off the minimal maint. road into a creek, and the others were used as anchors for me after i got them able to move.
mark salanco
greenville sc
Installed a pyro and boost gauge..pyro not working :(aua turned up the fuel a little bit, put new battery terminals on and bought two 395/85 r20 tires for the front. one front tire has a big cut in the sidewall, not good ho, and bought a new hemmtt wheel to from Keven Coosa 4X4..now i will have a mounted spare..yay me
