simp5782
Feo, Fuerte y Formal
9,268
Mason, TN
Putting in a little work with the deer skinning rack. Finally got it mounted with some help from a buddy.
Yeah I had the same idea. Got a crane instead since you can kill so many it's ridiculous in my part of TN
SandBar
Full Time Patriot
755
231
GA/FL
Started rust repair for a repaint. I’ll put a build thread together soon. I have been ordering parts in the meantime and this beauty just showed up. My OCD would not let me install a generic weights and dimensions plate and unable to find a General Products Division plate, Mike Virilli of Big Mike’s Motor Pool had a custom data plate made and I thought I would share it here like a proud father!View attachment 887997
Anyone sell new data plates for m54's? Looks great.
US6x4
2,087
Wenatchee, WA
For data plates I always look to Eastern Surplus and TNJ Murray. I believe Eastern Surplus purchased the entire inventory of Dataplates.net when they shut down. They both have data plates for older vehicles and I would think there's a decent chance they have some of the ones you need.
Micmada
211
Florida
I was doing my first oil change and fuel filter change and noticed that while the previous owner told me there was no power steering, I do see an hydraulic actuator on the driver side wheel pumping into a horizontal actuator to actuate the right side. It seems to require some kind of fluid and have not had a chance yet to figure how to top it off and with what fluid. Not sure which type of steering I am dealing with.
Suffice to say steering is a bit of a workout.
19,178
Wow!
Yep, definitely looks like power steering to me...
Gypsyman
738
Quincy, FL
That looks like the standard air assist unit to me. No fluid required. Just air from the compressor. Is there an air cylinder down on the front axle?
Micmada
211
Florida
I will check but it makes sense. When I do parking maneuvers I hear air bleed valves opening and releasing air. I was wondering if it was due to shifting but might have to do with steering back and forth.
Valley Rock
Big wheeler cat peeler
537
Rogue Valley OR
I opened the door and saw a little water on the transmission hump, realized there must be a hole in the roof, went up and sealed it with a dab of silicone .
That's what I did last week .
Here's what I'm going to be doing, but I don't know what week it will be preferably a warmer week .
After replacing all of the filters last summer for the first time since I've owned the truck, I encountered several problems .
One of which is now the oil filters leak, I believe that c&c did not give me the correct O-rings for the Deuce, but it's water under the bridge meow, I will be converting to spin-ons because they leak all over the place, plus this will give me oil pressure considerably sooner on Startup .
msgjd
2,870
upstate ny
Only the 5-ton M39-series and M809-series make air noises when shifting the tranny
