kungfu dave
Charlotte, NC
Thank you very much gentlemen for your assistance! I will forward the info to my mechanic who will hopefully have Frank up and running very soon. Here at the dotting I and crossing T stage and I don't want to leave anything to chance. Thanks again!
FullSpecial
104
Denton TX
It looks real good all around.
What is the "Over Speed" indicator (the center light, in the middle of the cluster), is that to warn if the RPM's run up too high, or just generally running faster than advised?
Ahab, That's a A2. It's for the CTIS. If you try to drive 55 in XC or Sand it will auto inflate to HWY.
Better question, why is the ABS light on?
twisted60
241
Jupiter, Florida
ABS light is back on...I switched the black box between the rear axles and when I did the power on it went out after 2-3 seconds, but shortly after i started driving it came back on, today I checked the 2 fuses and they are still good, so back to the TM's.
Not a show stopper, I still drive her but give myself lots of stopping room and keep my speed down. I did do a test "panic stop" on a gravel road, engine did not stall, so I'll keep driving her and keep trying to figure out the issue.
big block 88
17
Topeka/Kansas
Boy mine sure stalls quick fast and in a hurry under emergency braking. We had just got when a young gal almost pulled out in front of me doing 35 truck locked up and stalled. Wasnt a big issue stayed calm went to neutral restarted and put into gear went on my way. Also had a caged brake that i was told the cage bolt just stores like that in the pot. Turns out not so much and it was caged for no reason.
simp5782
Feo, Fuerte y Formal
9,285
Mason, TN
Make sure all your lines from your cans to your axle tree are hooked up correctly. Trucks that have spring brake cans with 3 ports vary from trucks with 2 port cans I have noticed. I hooked my regular 923 up just like 3 other trucks i had present and mine wouldnt move. It was weird. I would think at idle you would want air to the "emergency port" on the can. Several of my trucks have it going to the service port on the can when they have 3 ports available
Sent from my SM-G860P using Tapatalk
gottaluvit
Good info there. Thanks.
Another Ahab
4,203
Alexandria, VA
Got my 923 un stuck out of the yard. Sunk to the lug nuts with all the rain. Told my wife is did abstract land scaping.
Surely you have pics of that?!
I made ruts you could swim in, with my CUCV.. I could only imagine the devastation you'd make with a 900 series....
Yes, we want is pics (please):
- including the charming expression on the face of your Beautiful Bride on her inspection of the devastation...
I mean, renovation!
twisted60
241
Jupiter, Florida
Swapped out my heater box/core, it leaked on day 1, so I closed the valve at the engine block and did not look back, but as I'm trying to work off all the pending "to do's" I tackled it today.
Old core IMG_2999.jpg The old core blower motor did not work so when I installed the new box I got a new motor, ya I did not think about years of crud and a mouse nest that went blowing all over the cabIMG_3002.jpg Oh well nothing a vacuum can't fix.
