jaws4518
Cold Beer
141
Abilene, Texas
You will notice how high he was, pulling up killed the other puller, transferred ALL the weight to him, a sure win.
Yeah, if I had 20k of Ag tires on my truck I would be hard to beat also. Did RWP have to build a special road to get him into the place? If this guy shows up it will be interesting to see what his routine is all about. I bet he comes in on a low-boy with tires stacked. Then, he's got a mobile shop & crew working for two days to put the **** tires on. I only have 14k total invested in my rig. 10k for the truck w/17 hrs on it out of the depot, 2400 on new tires, oil, grease, and a few extras. I already won!
Elijah95
Certified Rookie
1,239
1,183
Georgia
Missed out on buying an M543 gasser for $2000, and had to pass on what “appears” to once have been a CCKW modified into a all out skidder truck for logging. What a shame.
sandcobra164
287
Leesburg, GA
Made and installed a patch panel for my doghouse thanks to Welder1. I cut a hole into it rather than remove it when I installed my dual fuel line set-up that Simp made for me. The cut I made was not very pretty but the cover panel makes it look factory. Now I need to buy some shrink tubing to slide over the bolt heads and build up some rubberized undercoating to restore the original insulation factor. That little patch panel gets hot! Other than that, drove 60 miles today and the old NHC-250 is running great. I even had to back out going down the expressway a few times as it will easily hit 2,200 rpm on the flats at maybe 1/4 throttle thanks to Simp's tuning advice. I even washed it some in preparation for a parade next weekend. Gotta get some paint for the hardtop!
simp5782
Feo, Fuerte y Formal
9,285
Mason, TN
I will send you the Injection pump I took off my NHC250 if you want to put it on for the rally and try it out.
simp5782
9,285
Mason, TN
Installed the 915 bumper. Did a few things to it today. Installed a extra air tank since doing the 915 battery box and drivers side tank i actually lost 2 smaller air tanks so I installed this bigger one on the bumper space.
I plan on doing a toolbox on the drivers side outer frame as well as a grate cover for the winch that will be on a hinge so i can fold it up to access the free spool.
Having to upgrade some fuel line for capacity reasons. Just not enough volume with the 3/8" hoses.
sandcobra164
287
Leesburg, GA
I think I'm good. I really don't want to change up something that's working good. I'm sure you're take off pump would be awesome and would only take about a hour to swap but I'm sticking to an annual oil change and lube job on the truck prior to going to Durhamtown. The less I mess with the less I can mess up. With it's current pump I have to back out considerably to keep it off 2,200 rpms on the flats in 5th gear. The shop that rebuilt the pump set it 10% over factory, I've turned the throttle shaft screw 1/2 a turn counterclockwise. It's pretty strong now and almost no black smoke under heavy throttle. I can't wait to ride in the Big Cam M923. The videos you've put on YouTube are awesome.
Spyderman
37
Alexandria KY
Took the truck to Heroes day here in Alexandria. To celebrate first responders and military. Had a good time. Bad thing is my alternator went out driving home. Now I need a new one before driving to the machine gun shoot.
Sent from my SM-N960U using Tapatalk
simp5782
9,285
Mason, TN
Should be able to pick up a brushless clone for $100 or so on ebay. Just gotta make some spacers for the bracket.
simp5782
9,285
Mason, TN
Man simp, I love your truck!
Its pretty nice now. Need a few more things and she will be set.
Added a Access panel to the winch today. need to add some hinges to the rear side but it hides it away pretty nice. Not bad for the rear tractor grates off a 915.
Brutacus
198
Marion, AR.
My Father and I just went through both rear axles. We found 3 bad/froze wheel cylinders (lots of rusty crud), all springs were rusted with no tension, a brake drum with some shallow heat cracking (still useable), and 1 bad inner bearing. We replaced with all new cylinders, seals, springs, push rods, and gaskets. We pressure washed all the gunk off before we put the new hardware on, so the hubs look clean now. Just waiting for Memphis Equipment to open so I can go pick up a new inner bearing. Yesterday I called every parts place open on Sunday, and after cross-referencing the part number, the closest store that had the inner bearing and race was in Little Rock. I'm not driving 2 1/2 hours to save $20 on the bearing. and race. Oh we found an easy way to put the inner seals on, and the ready sleeve/wiper ring on. The inner seals are kept in the freezer over night so the shrink some (much easier to drop them in that way). The wiper ring/ready sleeve spent 30 minutes in the over at 500 degrees, and they just slid on the spindle with out having to drive them on. Some time soon, I'm going to drain the rear axles and replace the old gear oil.HPIM2407.jpgHPIM2408.jpgHPIM2405.jpgHPIM2406.jpg
UPDATE
We picked up the new bearing from Memphis Bearing Co., They had the lowest price. If we had known of MHC, we would have went there Sunday, instead of waiting for Monday. Everything is back together now. Next I'll bee draining the diff oil and replacing with new.
simp5782
9,285
Mason, TN
The napa out here by my house has the bearing and race set in stock. You can use a 594a bearing in a pinch.
Also MHC Truck is open 24hrs 7 days a week and they keep a good many bearings in stock.
