- 4,258
- 1,713
- 113
- Edmond, Oklahoma
Plow setup looks good!
Luckily we don’t need those in Oklahoma on a regular basis.
well...... :/
I dunno if I should laugh, or cry. I wanna do both.
??? Care to explain, cause i'm lacking a bit of context here.Ripped the power companies smart meter clear out of the socket today. Thankfully no damage to the box
Lol. What have you done to your cucv today? I have been using it for a mobile scaffold to give the house a wash down. I ended up using it to rip that smart meter right out of the socket when I backed into it .
Show us how you use that square hole when the pulley is in place.Welded up the power steering bracket that broke, also finally found where that square hole was that is used to move the bracket when tightening the belt.
Charge the battery asap. A discharged battery left discharged will be permanently damaged in short order.I opened the inside door of the garage last night to make sure both overheads were closed before going to bed.
I heard a strange rhythmic knocking, or popping sound coming from the driveway. Put some shoes on and went outside the see what it was.
Turns out I left the Whelen siren/pa controller turned on in the 1009 and it had depleted battery 1 enough that its internal relay was disengaging and reengaging, causing the speakers to pop.
It's been parked since the Gen 1 light issue. The new alternator should be on the truck for delivery today, so hopefully back on the road by the weekend (if stuff would stop getting in the way!)
