What have you done to your CUCV today/lately - Part 2
Marauder4
Replaced the halogens with Amazon LEDs, but had to pull the side marker lights to get the LEDs to work right. Got new sockets for the side markers on the way. Pulled the trailer brake system and most of the snow plow wiring out to clean up behind the dash. Put the front bumper back on with some random shop bolts. Next up is deleting the load sensing valve and most likely running new hard/soft lines to the passenger's rear brake followed by a rear brake job.
Marauder4
Without necroposting, and if this isn't the correct spot, feel free to correct me, but if anyone has done the load sensing valve delete can you message me? It looks like a fairly simple procedure, but I want to see if there are any tips or tricks to make sure I don't run into too many hang-ups.
deank
The TSB recommending removal and the approved GM removal procedure:
GMC NUMBER: 88-T-151
GROUP: 5 - Brakes
DATE: August, 1988
CORPORATE NUMBER: 865010R
SUBJECT: REAR BRAKE SENSITIVITY - HEIGHT SENSING VALVE REMOVAL
MODELS: 1984-86 C/K 3500 AND 1987-88 R/V 3500
THIS BULLETIN IS A REVISION OF TRUCK SERVICE BULLETIN 85-B-79, DATED MAY, 1985, UPDATING FOR MODEL YEARS 1984-1988.
1984-1986 C/K 3500 and 1987-1988 R/V 3500 series trucks are equipped with a rear suspension height sensing device that optimizes the brake proportioning valve setting for the load the vehicle is carrying. The height sensing system adjusts the brake balance in vehicles subjected to a range of loading conditions. Occasionally, vehicle modifications by body builders or owners influence the height sensing device. If a vehicle has had rear suspension modifications that affect its trim height or the spring rate, and the driver comments about the brake modulation characteristics of the vehicle, it is recommended that the height sensing system be removed and the brake system be revised as described below:
Parts listed below are currently available from GMSPO.
1. Detach rear brake hose from lever and bracket assembly. Reference Figure No. 1.
2. Remove lever assembly and bracket from axle.
3. Install rear brake hose bracket (P/N 348978) and spacer (P/N 2355099) with a 3/8-16 x 1.38 bolt (P/N 358000 - shorter bolt removed in Step No. 2) in the upper cover hole. Reference Figure No. 2. Use Loctite 75 or equivalent on the bolt threads.
4. Attach brake hose to bracket with bolt from original installation.
5. Install a 3/8-16 x 1-3/4 bolt (P/N 9439637 - longer bolt removed in Step No. 2) through spacer P/N 14055556 (removed in Step No. 2) in remaining axle cover attaching hole. Use Loctite 75 on bolt threads or equivalent.
6. Disconnect brake pipes from height sensing valve and brake hose, and discard short brake pipe. Reference Figure No. 1.
7. Remove and discard height sensing valve, bracket, and bolts.
8. Carefully reposition the rear brake pipe, and connect it to the rear brake hose.
9. Bleed and test brake system per Section 5 of the appropriate Light Duty Service Manual.
I found this after a quick search online. Somewhere on a computer I have a copy of the TSB. Courtesy of someone on this forum.
Marauder4
GROUP: 5 - Brakes
DATE: August, 1988
Yup! Found that here too. Like I said, it LOOKS simple, I just want to make sure it IS that simple from someone who's done it!
Another Ahab
Happy 4th to everyone!
Hooked up the batteries to my M1008 and checked tire pressures after sitting for 6+ months...took it to the dump with a load of tree limbs...drove like a scalded dog!
Glad to heart your rig is running right fine, Abbyblind.
A Blazing Fourth to you, Brother. Long Live the Republic!!
LT67
I don't drive my 85' M1008 as much as I used to. Only a handful of times each month. The 86 M1008 aka the 💩box gets driven at least twice a week to run errands.
On that note I looked at a Vortech 350 to swap into the 86' M1008. The ole 6.2 is losing more compression and it needs to be replaced. I'll keep all of the diesel parts for future use..
Marauder4
Set about curing my death wobble today. New centering-link ends and new upper kingpin bushings and springs. Found out that the lower kingpins are most likely shot too. Got those kits and an inner tie-rod on the way.
Progression on the springs/bushings pics are new/driver/passenger.
