What have you done to your FMTV or LMTV today
Ryan31783
13
Southwestern Utah
I have been working on building a water tender and making some changes on another, between mounting a pump to a transfer case to change the direction of the pump, but to also make it 2 speed… then have been working on a now finished interior kit and finalizing parts for a center console for the fire truck, and also reverse engineered the dash reinforcement panels and door strap mounts for the door limiting straps.
j_boucher
61
Virginia
Reliable in your experience? I see lots of them around. I also have the smaller 14volt version. This one seems robust, 1500va transformer inside and very large smoothing capacitors.
Never had issues with them even with all the dust and dirt and two theaters of use / Did blow up one when the camera had short and it made a very loud Bang
MatthewWBailey
Father, Husband and Barn Hermit
914
Mesa, Colorado
Does that t-case mount to the existing one or between? That's pretty cool
Ryan31783
13
Southwestern Utah
The transfer case is the yellow Dana that’s mounted to the frame of the truck but the pump is mounted to the top of the trucks transmission/transfer case. It shouldn’t be too big of a deal because it shouldn’t ever be subjected to a shock load. It should be pretty linear. The pump mount is all .25”
MatthewWBailey
914
Mesa, Colorado
So how is the Dana case driven?
Wingnut13
560
Strafford, NH
I finally got me some new sneakers! First one almost all put back together. Had a hard time finding the correct tan color in flat locally, so I just went with black. I needed to clean up some rust that was beginning.
Ronmar
6,696
Port angeles wa
Ok, so left side PTO drive to the 2speed Dana Vdrive and back up to the pump over the transmission? I like it. What PTO drive did you use? Are you looking to use this while driving? If so, you may need to tweek the allowable PTO RPM limit settings in the TCU. Our local FD district where we store some of our sheriffs equipment were running some wildland training the other day, running a hose along the roadside while moving slowly, practicing fighting a ditch fire. They only have 2 rigs that can engage pump while driving… I was teasing them about walking the truck on a “leash” hose:)
