What have you done to your HMMWV today/lately
rcamacho
818
Bainbridge Island Wa
I've seen HMMWV in Rifle Companies using a piece of plywood between the Windshield and B Pillar above the Driver and Truck Commander's seats with the M113 APC dome lights screwed or bolted to, along with map pockets, pen slots, etc. We were allowed to make NON-PERMANENT alterations to the trucks most of the time a piece of 1/2" or 3/4" plywood bought by the crew or senior person, painted black or OD using supply system or AAFES bought spray paint.
Love to see pictures of in field modifications like this.
92
88
Perrysburg OH
That sounds like a great idea. I would have to run a ground wire to the light but putting an overhead organizer on it is genius. I tell ya some of the best ideas come out in those field mods.
Chief B
64
Milton, FL
So I’ve refurbished two interior lights and was looking for options to mounting these. I want to put one over each front seat. I’d like to either mount to the front roof bow or between the bow and the B pillar. Any ideas or thoughts would be great. Thanks
Not sure if this will help you too much or not, but the person I purchased mine from had mounted my speaker bar in the space behind the B pillar so here are a couple pictures on how it was done. This may give you some idea on how you can mount between the windshield and B pillar...
Mogman
8,584
Papalote, TX
I used the PS pump diag flow and pressure gauge from my HMMWV tool kit to test the civilian remote reservoir Saginaw P series pump that I had re-calibrated and fitted to my M998, it passed all tests except the idle pressure with no steering or brake input, instead of being around 185-200 PSI it is around 300 PSI, this of course would not be a pump issue and I contribute it to the 12K MileMarker winch being in line, unfortunately I did not test the stock pump but it steers easier than it did before.
Ajax MD
1,412
Mayo, MD
Practical applications:
We drove down to the local nursery and had them load 1.5 cubic yards of top soil for the addition to our veg. garden.
My wife was practically giddy at getting to use her truck for real work, not having a bunch of empty, plastic soil bags to dispose of, and not trashing her daily driver with dirt.
The truck rode a little nicer with some weight in the back. The engine didn't even notice.
TOBASH
3,140
Brooklyn, NY
How did you make those planters? Please PM me.
Milcommoguy
2,123
Rosamond, CA
Drilled out all the twist locks on the back of the "B" pillar. Never did like them and of no real use in my helmet top rig.
Took a 4 foot length of 3/4 X 1/8 aluminum strap. Centered it up where I wanted it over all the 1/8 holes and transferred a few locations to the strap.
Placed 3/8 spacers between pillar and strap with long rivets to hold it all together.
Holly Molle you are asking , for what is it????
It is the Molle hanger rack for small Molle Pack Type gear. I keep registration paperwork, small gadgets and goodies all at the ready AND out of site and water.
So that's what it is... the Holly Molle HumV glove box, CAMO
Rail showing location and spacing
With MOLLE systems attached
Humv MODS U can DO.............. GREG.... NOT AUTHORIZED FOR USE IN TEXAS
fuzzytoaster
2,912
Fort Worth, Texas
I'll be doing headgaskets soon...:mad: 77 miles on the odometer on pick up (stamped 09' reset at 17 miles). Serviced all fluids, performed 500 mile break in procedure as mandated, blew a gasket at 812 miles. Starts instantly, runs like a champ, even with the issue but all signs say bad head gasket. I don't know whether to blame bad overhaul, faulty material, or what until I get into it. It never overheated as I caught it in time.
92
88
Perrysburg OH
I found these handy dandy items for storage. They also cover up unsightly rips and stains. 50DA06D4-D46B-4C3F-9B3C-FBB0A8E30BD8.jpeg
Awol
354
MA
That sucks. Are you seeing coolant in the oil? I'd pressure testing the system before totally ripping it apart.
fuzzytoaster
2,912
Fort Worth, Texas
Caught it before coolant mixed (at least visually). There's peculation in the coolant reservoir as well as black specs from exhaust particulate, white sweet smoke, and coolant is disappearing. I wanted a second opinion and had a mechanic friend look over it and he came to the same conclusion.
Coug
4,161
Olympia/WA
sweet smell, bubbles in coolant, disappearing coolant together definitely sounds like a head gasket to me.
  • Like
Reactions: REF
Awol
354
MA
Certainly sounds like a HG took a dump.
Might as well do both sides while you're in there.
  • Like
Reactions: REF
TOBASH
3,140
Brooklyn, NY
A new rebuild going bad is suspicious.
I would magnaflux or UV dye the heads and the block.
You might have a crack.
Before pulling the heads, run EGT's to ensure temps are not too high.
You sure fuel injector system not advanced on this fresh rebuild? That would elevate EGT's and cause damage.
Best,
T
