Wider rear tires than 14.00R20's for M929A2 dump truck?
Jbulach
2,071
Sunman Indiana
Sand trails?
Hello Ladoublet!
I believe you said you would be off-road only, but what are you doing with your truck, how much weight, and at what speeds are you hauling?UploadFile1649338365.986774.jpg
I was considering Sand trails at one point for extra flotation in farm fields, but we have a lot of steep hills, and field stone here, I decided not to risk a rollover by overloading a soft tire.
Jbulach
2,071
Sunman Indiana
If I remember correctly your within the limits of Sand Trails at that weight, and speed, but if you’re looking for stability in the hills to prevent a rollover, they won’t help with their low air pressures, same rim width, and think they would puncture much easier. I was hoping maybe you were looking for more flotation in flat fields…
