wrecker boom control, need help fixing
drjconley
merced, ca
I have a m62a2. The boom up down control is not working. It was working fine until I think I pushed the control too far forward. Now it will not go up, I can hear fluid being diverted, but it appears to either lower or bypass the boom up ram.
Does anyone have any suggestions on where to start to either fix or replace the control lever?
Thank You,
Jim
drjconley
merced, ca
I am assuming that is when it happened. I was working the boom, everything was working fine, and then when I was picking up the boom I pushed the boom up control forward to the stop. After that the control would no longer work. It will go down, but it wont go back up. In the up position, the boom will start to go up, then it will go down just like it is in the down position.
Does anyone have any suggestions or the TM number on where to start to fix the control.
As always thanks for any help.
Jim
gimpyrobb
dumpsterlandingfromorbit!
27,785
748
Cincy Ohio
Have you looked to make sure the pins are in place(at the bottom of the stick)? My M62 had a pin come out and it would go down but not up, or go up but not down. It is an easy fix.
drjconley
merced, ca
I pulled off the cover yesterday, but I quickly realized I didn't know what I was looking for. I will check that out as soon as I can and get back to you. I hope the fix will be that easy, but if history has taught me anything, I am not planning on it. Most of my projects have a tendency to grow in both size and expense.
Jim
gimpyrobb
27,785
748
Cincy Ohio
There is a pin at the bottom (I think) and it is the pivot point for the plunger to pull out or push in. I might have had to screw in the part that goes in/out. It has been a while, sorry.
drjconley
merced, ca
Gimpyrobb, thanks for your help. I appreciate all help given. Is there a TM related to the hydraulics on a M62? I like to read up on what I am about to do.
Jim
drjconley
merced, ca
I read the book from the crane manufacturer, it had some good info. Is there a TM with flow charts for repairing the crane and associated parts. I am looking for something that has lots of soldier A and soldier B.
Jim
