jake1086
- 23
- 18
- williston ND
I bought this ol beastie and need to get it home about 2 hours. Does anyone know what this thing weighs?!?!
That is really cool. I'd assume there's a data plate either inside on the dash somewhere. Or on the door jamb that would state the weight of it. That's gonna be a interesting tow. You'll need a long landall or something along those lines to tow it I think. Unless there's a shackle point up front to hook a towbar or a wrecker to hook to.
@jake1086 that paint scheme would look very neat. Can you imagine recreating one of those trailers and taking the complete rig to shows? I wouldn't think an original trailer survived (in the wild; outside of a museum). You definitely grabbed a rare truck!
Those trucks, if I recall correctly were supposed to be scrapped. The trailers were supposed to be scrapped as well. That was part of the START treaty that saw the removal of the Minute Man (MM) 1 and 2. All the silos except one were imploded, again as the result of the START treaty.
I spent 10 years in the missile fields. I was assigned in 1996, which was about the time the MM2 was removed from service. I saw the end of Peacekeeper as well. Anything related to ICBMs gets into levels of classification I won’t try and go any further.
That truck is a rare find. It had to be capable of moving a MM 1 from point A to point B then set the missile in the launcher. The missiles weighed in excess of 100,000 lbs.
If you are concerned about them reaching out to you, there is a possibility of determining its ownability. The Air Force Museum at Wright Patterson AFB is my #1 go to for all such questions. Second option is find the stock number on the data plate. It can be used to research anything and everything that ever was about that stock number. I know I can search the FedLog database. It’s usually up to date, usually. And finally, someone can contact the people over at Warren AFB. Actually, they’re the first and best people to talk to.They're heavy for sure loaded weight was 133,000 in total according to the Web. Part of me hopes you're right and every other one besides air force bases is scrapped, part of me wonders if they'd come looking for me![]()
