M1123 Radio Tray Brackets
tjonesdfw
64
Coppell, Texas
Does anyone still sell the bracket that goes between the cowl/dash and the radio tray for the M1123 or are classifieds or fleabay the only source?
nairb
109
33
Liberty Hill, TX
Anyone have the part number for the brackets that connect the upper and large lower tray? Or does anyone have an extra set? See picture:
EDIT: looks like it might be 12340134 / 2590-01-202-8546, which seems like everyone is out of stock
Crapgame
321
Navarre, FL
Awesome, how much do you want for them?
I've located 2PAIRS in that bolt hole forward configuration, one pair aluminium in CARC Tan686, one pair steel in black.
Those HVAC vent angle adapters, I'm going to tell you, the original GI ones are teh suxs. The 1/4-28 threaded stud is only pressed into the hole. The stud strips out of the hole in the angle bracket and just spins are you try to remove the nut. You'd be better off using 1/8" steel angle to make your own.
juanprado
2,760
Metairie/La (N'awlins)
The brackets pictured above are usually on the bottom tray to mount to the tunnel. The bracket on the top of the tray for dual trays is a U shaped piece but only one set of holes to mount it as not adjustable.
See this pic on my thread Juan's M998:
