block heater boiler
100acre
Bonners Ferry, Idaho
How long in advance should my block heater in my 1008 be plugged in before starting her up ? Last time I left it in all night the coolant was near boiling and there was coolant on the floor as well. She sprang a leak.
dependable
187
Tisbury, Massachusetts
What is wattage of your block heater? Some of the tank types are pretty fast. I have found that an hour or so makes a big difference with any of them. If it is below 15f a couple hours is better. In arctic temps all night is probably good. Block heater should not cause any leak that wouldn't have eventually happened at working temp. One reason not to leave on over night is that they spin the electric meter pretty well($). I have outlets in parking area switched from inside so I can plug in at night and switch on in morning.
BIG_RED
Winnipeg, Manitoba
I usually leave both of mine on all night (2x 600watt in-block frost plug heaters - 1200 watts total) in the winter(-40* sometimes). If it's close to freezing temp (32*F) - i only run one (600 watts). Electricity is relatively cheap here ($0.06/KWH), and I need the truck. You should not be able to "overheat" your engine with a 600W heater.. It's an awful big chunk of metal with 4 gallons of water in it, and once the water heats up real hot, it should open the t-stat and convection would run the water through the rad (keeping it around operating temp). Sounds like something is very wrong. Unless you're block heating in the summer or something (I did that once when my glowplugs fried. Got hot enough to start, but nowhere near overheating, with 1200W worth of heat).
boondock
Anchorage, AK
As has been mentioned the tank type heaters work pretty quickly. At zero degrees my m1031 is good to go after about 1.5 hours.
Using a timer that fires up the heater before your usual startup time cuts down the electric usage compared to having the heater run all night.
islandguydon
783
Michigan
On a 6.2 if you have a 1500 watt heater I would go 1/2 hour if under 10 degrees, 600 watt an hour. I have left mine plugged in all night and have never had a problem, knock on wood. Auto zone has a 300 watt heater that I feel could be plugged in all night and your good and toasty. Probably cost a dollar to do so.
DonK
Social Circle,GA
Can you add a thermostat? I put in a 1800 watt that has a thermostat, on at 80 degrees off at 100...Works very well connected at the output of the Heater core...
ODFever
Madness Takes Its Toll...
73
Orlando, FL
DonK:
I'm interested in the heater with the thermostat that you installed. Could you please post the make, part number, and where you got it?
Thanks!
biggestc69
Council Grove KS
I have a 1500 watt Kats tank heater. Thing works great. Use an outdoor timer to start it about an hour and a half before I go to work. We have had a few single digit mornings here and she fires right off after the glow plugs get done cycling.
DonK
Social Circle,GA
DonK:
Thanks!
OD,
It's a 1500watt Kim Hot Start, P/N-326228. I've have it for quite sometime. You may be able to get one from NAPA, not sure. If not, check with your location Generator Service Company, that's what this was intended for.
Follow the instructions that come with it you should be good to go...
