wired1000
- 0
- 0
- Chicago, IL
Hi all,
It's gotten pretty cold out, and I've started to hear a funny noise... A hissing sound, like compressed air escaping. Seems to be coming from the front of the vehicle.
It seems to happen when the engine is at higher revs, actually it seems like it happens mostly at times when the trans should be shifting, so like higher revs but not even-higher revs (hard acceleration makes it go away).
I can't reproduce it all the time, but it's been happening more and more. As this is my daily driver, I need to figure out what's up and make it go away. The vehicle seems to be operating just fine, only making this funny sound which it didn't used to do.
I saw another thread which mentioned a hissing sound... a guy's transmission wasn't shifting at all. I was planning to start by replacing all the vacuum lines.
Any other ideas?
Last bit of info which may or may not be related. A few weeks ago I tightened up my flex plate bolts, and during that operation I had loosened one of the trans oil cooler lines. I forgot to tighten it, and ended up leaking a lot of fluid... so when I noticed that, I added 1.5 quarts and tightened the line, which seems to be holding. I only mention this because.... ??? maybe it's related?
Appreciate your help in advance!!!![A toast to MV's :beer: :beer:](https://www.steelsoldiers.com/images/smilies/beerchug.gif)
(Btw I've got an M1009 which doesn't seem to be modified other than having a NP205... engine/trans is stock)
Any other ideas?
