My factory GM wheels are only 6.75" wide. I have been very pleased with this setup for my needs. The HMMWV radials have been impressive at their price.Rather than start a new thread I figured I would use this one. I got some 16.5 inch rims today that are about 6 inches wide. Will this work with 12.50 inch wide humvee tires?
I had a the same issue with my 9.75" rims, I think it's just the nature of the sidewall strength compared to the weight of the vehicle. HMMWV's have some weight on them.My factory GM wheels are only 6.75" wide. I have been very pleased with this setup for my needs. The HMMWV radials have been impressive at their price.
One thing about the skinny wheels is that with very low tire pressure, less than 10#, the tire deflects (sqats) very little. This makes it impossible to tell the tire is low by visual check particularly on the rear when not loaded. Tire thumper becomes the quick check. One benefit to this is the force maintained to the wheel's bead keeping the tire seated at lower pressure. - A popular topic for 16.5"s with no beadlock.
More details and pics in my signature link.
I actually did not have mine balanced at all. The only notable vibration I get is after the truck is parked for a while. After a few miles the flat spots are gone. I took them to a shop to be mounted. No trouble at all.Well looks like ill try it then. Were they hard to get mounted or balanced?
I frequently run 50-60 actual mph (gps verified, spedo not corrected for tire size). I have run as fast as 70 mph for 30 minutes. Anything over 55 mph for very long is rare. No increased vibration at the higher speeds.Have you drove it on the freeway at all or 50 plus M.P.H?
